It is currently Sun Jul 27, 2025 7:46 pm
PostPosted: Thu Aug 04, 2005 6:47 pm
I did a couple of rosettes which contained ebony recently and have another onr to do, I had a hell of a time eith the dust from the ebony rosette and bindings getting into the top, I was wondering if there is a simple method for preventing this or cleaning the top after, I wondered if it would be worth giving the top a thin seal coat of shellac before I start ?
PostPosted: Thu Aug 04, 2005 10:08 pm
Russell thats what I do. It helps a lot. Of course I havn't installed a rosette in so long I think thats what I do.
PostPosted: Thu Aug 04, 2005 10:11 pm
Bob
thank you
PostPosted: Thu Aug 04, 2005 10:12 pm
[QUOTE=Bobc] Russell thats what I do. It helps a lot. Of course I havn't installed a rosette in so long I think thats what I do. [/QUOTE]
Bob, you need to get building again! All that knowledge is starting to seep out. Patch those neural holes and get buildin'!
PostPosted: Fri Aug 05, 2005 2:02 am
Bob, you need to get building again! All that knowledge is starting to seep out. Patch those neural holes and get buildin'![/QUOTE]
Actually I was thinking of taking a ride up to your place for a refresher course.
PostPosted: Fri Aug 05, 2005 3:30 am
The shellac is the trick, a little shellac also helps the prevent small dings. doesnt eliminate the possibility but helps
PostPosted: Fri Aug 05, 2005 3:52 am
i am assuming that you are refering to the dust from leveling the rosette with the top; easy solution is to use a scraper; voila, no dust only shavings.
PostPosted: Sun Aug 07, 2005 9:19 am
Hi Michael I would normally, but in this instance The ebony has mop inlayed.
